02-28-2006 04:03 AM
03-01-2006 01:25 PM
03-02-2006 04:57 AM
03-02-2006 06:09 AM
Use the identifier K(/KChannelnumber [/IIndexchannel]) to display the values of the specific data channel as symbols. The parameter /KChannelnumber specifies which data channel DIAdem takes the numeric values from.
I hope this will help you.
Greetings
Walter
03-02-2006 07:29 AM
03-02-2006 09:39 AM
03-02-2006 09:44 AM
Sorry, I fourgot
see attach
03-03-2006 06:36 AM
03-03-2006 08:17 AM
For me it works... lets see: following your attached picture you need to have 2 channels as follows:
x-channel: 1, 2, 3
y-channel: 45%, 45%, 10%
Then you plot the bar chart… on the x-axis label you will have 1, 2, 3 (in that case) to convert that to a string you can use the function that you proposed (first remember to copy the function into the file UserCmdExample.VBS)
Now double-click on the x-axis label and on the “format” insert the command @@AxisText(CFV, "TV") where TV is the DIAdem variable that I used. Don’t forget to initialise the variable with the values that you want:
TV(1)= “OK”
TV(2)= “FAIL”
TV(3)= “NOT TESTED”
Hope this helps,
Marc.
03-03-2006 08:50 AM
