Hello teki,
are you talking about a fresh DIAdem 10.0 Evaluation installer you downloaded from out homepage, or did you get our Servicepack 1 for DIAdem 10, which is a selfextracting ZIP and does not include DIAdem Itself.
To download an Evaluation Verion, which is a complete installer (unpack and start with setup.exe), you can go to our ftp server: ftp://ftp.ni.com/evaluation/diadem/pc/
To install the servicepack (by executing the exe inside the DIAdem root folder) you need to have DIAdem 10 installed.
If this does not answer your question, please give me some more details such as
- where did you download the installer
- which EXE file are you exactly talking about
- when does the errors occure
- which operating system do you use?
regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
