DIAdem
formatting time date dd/mmm/yyyy
I am trying to format a date to a specific format DD/MMM/YYYY which is a 2 digit day, 3 character abbrievated month, 4 digit year.  I'm pulling the date out of a csv file generated by the DAS software into a double array.
Using the TTR function to convert an odly formatted date to a number and then taking that number and reformatting the date.  Though this proves to be complicated because the format of the date can change from m_d_yyyy to m_dd_yyyy to mm_dd_yyyy and the ttr function can only handle the one format it is given.
For a normal format it works, adding another M in the month section does not accieve a 3 character abbrievated month
        CALDAT = ttr(1_2_1234,"m_dd_yyyy")
        caldat = str(caldat,"#d/m/yyyy")       ' returns 2/1/1234
        caldat = str(caldat,"#DD/MMM/YYYY")  'returns 2/1/1234
Are 3 character abbrievated dates even an option? or do I have to script a string split match loop to convert a date... it seems like reformatting a date should be easier than that.  Does anyone have any graceful ways to easily convert date formats?
(5,994 Views)
Hello Frizzit,
The format string for months to show up as letters instead of numbers is #t in place of #d or #D
#dd/ttt/yyyy = 27/Apr/2012
The difference between "d" and "D" is explained here:
m or M Month
d or D Day
y or Y Year
k Calendar week
h or H Hour
n or N Minute
s or S Second
f Fraction of a second. DIAdem calculates a maximum of 4 places.
If you use the uppercase in the format instructions above, DIAdem deletes leading zeros and replaces them with a blank character.
The format specification hh:nn:ss results in 01:01:00, the format specification HH:NN:SS shows 1: 1: 0, and the format specification HH:nn:ss displays 1:01:00.
Use the following format instructions for months and days of the week:
#t, #tt Months with 1, 2 ... Character
#w, #ww Weekdays with 1, 2 ... Character
#T Full Months written
#W Full Weekdays written
I hope this helps, let us know if you have additional questions,
      Otmar
Otmar D. Foehner
(5,990 Views)
I didn't see the t's when I was looking, thank you for that.  Standard VB, from my experience is/was MMM.
CALDAT = doubarr(c,21)
CALDAT = Replace(CALDAT,"_","/",1)
CALDAT = str(datevalue(CALDAT), "#dd/ttt/yyyy")
Works well
(5,986 Views)
