DIAdem
diadem 2015 connectivity vi's still calls diadem 2012
I installed diadem 2015 and I still have diadem installed when i run my Ladview program using the diadem connectivity vi's they still call diadem 2012 how do I call dadem 2015?
(3,127 Views)
Hi 321,
The default mechanism for ActiveX is to call the version of the given program that was most recent run manually.  Try opening DIAdem 2015 manually, then re-running your VI and let us know if that doesn't do the trick.
Brad Turpin
DIAdem Product Support Engineer
(3,095 Views)
That dosen't matter even if I have Diadem 2015 open the code still opens anthe closes Diadem 2012.
(3,075 Views)
Accepted by topic author 321
Hi 321,
Are you by chance using DIAdem 2015 64bit?  You'd need to run a 64bit version of LabVIEW in order to talk to a 64bit version of DIAdem via ActiveX.
Brad Turpin
(3,063 Views)
Yes that was the problem Labview 32 bit and Diadem 64 bit I unistalled Diadem 64 bit and installed Diadem 2015 32 bit and everything works fine now thanks for your help.
(3,052 Views)
