DIAdem
dfdfdf
Hi
In Call storage import i have declared the ABS key as a variable
BUt its not working with the array.Please go though the attachment
(3,464 Views)
Hi sajeesh,
I have a solution for you.  Place both the attached VBScripts in the same folder somewhere, then run the "Load Citadel Window.VBS" in the SCRIPT panel.  You can choose which traces, which time window, and which interpolation options you prefer.  There's also an option to remove NoValues and another option to merge all the loaded Citadel Groups into one Group with a common DateTime channel (only if you apply a time window though).
Brad Turpin
DIAdem Product Support Engineer
(3,436 Views)
