12-04-2014 02:58 PM
Hey everybody,
I am attempting to add to my script the scenario described in this message title: Delete a group if any channel contains a novalue. I have tried the following script but it doesn't seem to do anything at all when I am using a data set with a group that I know has a channel called temp with novalue as the minimum.
dim i
for i=1 to data.Root.ChannelGroups.Count
if Data.Root.ChannelGroups(i).Channels("temp").Properties("minimum").Value = Nv then
Call Data.Root.ChannelGroups.Remove(i)
else Data.Root.ChannelGroups(i).Channels("temp").Values(1)=Data.Root.ChannelGroups(i).Channels("temp").Values(1)
end if
next
if I run this script, the group with a novalue "temp" channel still remains. Thanks for any help.
12-05-2014 12:42 AM
Hi crockengineer,
it is helpful to calculate the channel characteristic values first and then to check a property which tells you whether a channel contains NoValues or not. Here is an example:
dim iLoopG, iLoopC, oGroups, oGroupChns, bDelGroup Call ChnCharacterAll ' calculate all channel characteristic properties set oGroups = Data.Root.ChannelGroups iLoopG = 1 do while iLoopG < oGroups.Count bDelGroup = false set oGroupChns = oGroups(iLoopG).Channels for iLoopC = 1 to oGroupChns.Count if oGroupChns(iLoopC).Properties("novaluekey").Value = "Yes" then bDelGroup = true exit for end if next if bDelGroup then oGroups.Remove(iLoopG) end if iLoopG = iLoopG + 1 loop
Greetings
Walter
12-05-2014 12:47 PM
Thanks Walter_Rick.
I was able to make this work partially. However, if two groups that contain a novalue channel are one right after the other (say group 3 and 4), then this script will delete the group 3 but not the group 4 since group 4 becomes group 3 when the first novalue group is deleted. To solve this I added the following after the last endif:
if bDelGroup then
iLoopG = iLoopG
else
iLoopG = iLoopG + 1
end if
loop
12-09-2014 12:50 AM
You're right and if the last group contains a NV it was also not deleted. Here is a new version:
dim iLoopG, iLoopC, oGroups, oGroupChns, bDelGroup Call ChnCharacterAll ' calculate all channel characteristic properties set oGroups = Data.Root.ChannelGroups iLoopG = 1 do while iLoopG <= oGroups.Count bDelGroup = false set oGroupChns = oGroups(iLoopG).Channels for iLoopC = 1 to oGroupChns.Count if oGroupChns(iLoopC).Properties("novaluekey").Value = "Yes" then bDelGroup = true exit for end if next if bDelGroup then oGroups.Remove(iLoopG) iLoopG = iLoopG - 1 end if iLoopG = iLoopG + 1 loop
Greetings
Walter
12-09-2014 08:16 AM
In the case where I'm deleting items from an array (or in your case a channelgroup) so that shifting happens, I find looping starting at the end and working toward the beginning to be the simplest method. This eliminates any problem with shifting.
