NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
bricem13
Accepted Solution
default configuration Report
Hello I hope I'm not creating a dump. anyway. One big quesiton about diadem: I use always the same display type: 2D graph with several curves and axes. The default font size is 3 (too big), the default curve thickness is minimum (too thin), no marker on cureves and so on and so on. Is there any way of changing the default values for that? Best regards, Brice
Active Participant
cheggers
Re: default configuration Report
Hi bricem 13,
Please see the DIAdem Help for predefined settings:
"Changing Standard Layouts in DIAdem REPORT
Use the default function to specify standard layouts in the function groups for tables and axis systems. To assign a user-defined 2D axis system to a button in the 2D axis system function group, complete the following steps:
1. Select the DIAdem REPORT panel.
2. Click the 2D Axis Systems group bar.
3. Right-click a button in the function group.
4. Select Predefined Setting from the shortcut menu.
5. Select Yellow as the background color.
6. Click Change.  DIAdem makes the change. If you click the button in the function group again and position the new axis system in the worksheet, the new axis system has a yellow background."
cheggers
Member
bricem13
Hello I come here once more because one thing is still not solved: how do I define default curve settings like markers, thickness and so on ? Best regards, Brice Méalier
Trusted Enthusiast
Brad_Turpin
Hi bricem13,
To my knowledge it is not possible to configure default properties for new curves dragged from the Data Portal onto a graph in DIAdem.  I agree that this would be an excellent feature and have officially asked R&D to consider this for the future.
Brad Turpin
DIAdem Product Support Engineer
Member
bricem13
Hello Brad, It could be a good thing... Also there is no way of selecting several curves and changing their settings, which turns into a nightmare when several curves need to be changed... Best regards, Brice
Trusted Enthusiast
Brad_Turpin
Hi Brice,
Configuring multiple curves simultaneously is a feature that my counterpart PSE, Walter Rick in Germany, is already championing, so I am quite hopeful that we will see something on that front in the next couple of years.
Thanks for the feedback,
Brad Turpin
Member
GMJeff
Hi Brad,
I was wondering if this old issue has a solution.  I just encountered the desire to have the 2d graph default to my preferences, not Diadems.  For instance, legend configured the way I like it, no Y-axis labels, etc.  It's frustrating to have to keep changing these setting for every new graph.
Trusted Enthusiast
Brad_Turpin
Sorry Jeff,
DIAdem 2012, just released this month, does not offer any new features in this regard.  One thing to note here is that for several versions now you can apply some of the graph settings from one graph to all the others on that sheet and other sheets.  That might help, though it's not what you're asking for.
Rest assured that the feature request has been registered with R&D and has my full support.
Brad Turpin
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
