10-24-2005 10:50 AM
10-25-2005 10:25 AM
Hi Nuria,
The StatBlockCalc() function has the ability to calculate statistical results such as SUM based on a selected row subset, so the problem basically boils down determining which rows correspond to the same days, then running the statistics calculation only on those rows. You could determine these row ranges with FormulaCalc functions, and that would be preferable if you wanted to cut out those rows from each channel and create a separate group for each day. If all you want, though, is to calculate the daily sums, then it's a little easier to do this in a VBScript function.
Try out the below code,
Brad Turpin
DIAdem Product Support Engineer
OPTION EXPLICIT
Dim DayRows, SumChs, DayVals
Call GroupCreate("Daily Totals")
Call GroupDefaultSet(GroupCount)
SumChs = Array("Date", "Temps", "VALDEB", "VALFIN")
Call GetDayRows(DayRows, SumChs, DayVals)
Call CalcSumChs(DayRows, SumChs, DayVals)
'-- GetDayRows() -- -- NEW SUBROUTINE --
Sub GetDayRows(DayRows, SumChs, DayVals)
Dim i, k, iMax, DayChNum, DayValStart, DayRowStart, DayCurrVal, DayRowStr
DayChNum = CNo(SumChs(0))
iMax = ChnLength(DayChNum)
ReDim DayRows(iMax)
ReDim DayVals(iMax)
DayRowStart = 1
DayValStart = ChDX(1, DayChNum)
FOR i = 2 TO iMax
DayCurrVal = ChDX(i, DayChNum)
IF RTP(Abs(DayCurrVal-DayValStart), "D") > 1 THEN
Call UpdateDayRows(DayRows, k, i, DayRowStart, DayValStart, DayCurrVal, DayVals)
END IF ' next day
NEXT ' i
ReDim Preserve DayRows(k)
ReDim Preserve DayVals(k)
End Sub ' GetDayRows()
'-- UpdateDayRows() -- -- NEW SUBROUTINE --
Sub UpdateDayRows(DayRows, k, i, DayRowStart, DayValStart, DayCurrVal, DayVals)
k = k + 1
DayRows(k) = DayRowStart
DayVals(k) = DayValStart
IF i > DayRowStart+1 THEN DayRows(k) = DayRows(k) & "-" & CStr(i-1)
DayRowStart = i
DayValStart = DayCurrVal
End Sub ' UpdateDayRows()
'-- CalcSumChs() -- -- NEW SUBROUTINE --
Sub CalcSumChs(DayRows, SumChs, DayVals)
Dim i, j, iMax, SumChNum
iMax = UBound(DayRows)
FOR i = 1 TO 22
StatSel(i) = "No"
NEXT ' i
StatSel(2) = "Yes"
StatClipCopy = 0
StatClipValue = 0
StatResChn = 0
Call ChnAlloc(ChnName(SumChs(0)), iMax, 1, DataTypeFloat64, "Time")
SumChNum = CNoXGet(GroupCount, GroupChnCount(GroupCount))
ChnLength(SumChNum) = iMax
FOR i = 1 TO iMax
ChDX(i, SumChNum) = DayVals(i)
NEXT ' i
Call ChnCharacter(SumChNum)
FOR j = 1 TO UBound(SumChs)
Call ChnAlloc(ChnName(SumChs(j)), iMax)
FOR i = 1 TO iMax
Call StatBlockCalc("Channel", DayRows(i), SumChs(j))
ChDX(i, SumChNum) = StatSum
NEXT ' i
NEXT ' j
End Sub ' CalcSumChs()
10-25-2005 10:48 AM
Hi Brad,
I tried out your code and it gave me the following error:
**** Error registered on 25/10/2005 at 17:41:56 [Message file:GFSAUTED / Text area:4 / Text number:1]
Error in <NoName(1).VBS> (Row: 79, Column: 7):
No suitable channels have been specified!
(channel length 0, channel number 0 or too high)
It stops at this line: Call StatBlockCalc("Channel", DayRows(i), SumChs(j))
I don't know why this happens.
**And another question: Is it possible to add the "minimize button" in a dialog window created with the dialog editor of DIAdem v 9.0?
Thanks a lot!
Núria
10-26-2005 08:41 AM
Hi Nuria,
I did not try out the code on a DIAdem 9.0 version. I was able to reproduce exactly the error you reported with DIAdem 8.1 (which I had handy), and the following minor change got rid of that error:
Call StatBlockCalc("Channel", DayRows(i), CNo(SumChs(j)))
There is no way that I know of to add a "minimize" option to a SUDialog, but this is for a good reason. The SUDialog is modal-- meaning nothing can happen in DIAdem until it quits. If you were able to minimize it, DIAdem would still be unresponsive until the SUDialog quit and the VBScript that started it ended. Long term we would like to have non-modal SUDialogs, and that would be the point when a "minimize" button would really make sense.
Brad Turpin
10-26-2005 08:51 AM
Thanks a lot Brad!
I tried the code and it works fine.
And thank you once again for the explanation about the modal SUDialogs!
Nuria
