DIAdem
comment mettre dans une légende le nom de l'échelle associé à une courbe
Hello
I would like to automatically write the name of the scale related to a curve on  the legend, How can i do that
Thank's
CC
(2,954 Views)
Hi CC,
The process is slightly different depending on whether the graph is in VIEW or in REPORT.  In VIEW you can simply double-click on the legend and select the "unit_string" property from the list of available channel properties on the left of the dialog.
In REPORT you should double-click on the legend, then select "Free text" as the labeling mode, then type in the expression:
@ChnDim(CCN)@
Brad Turpin
DIAdem Product Support Engineer
(2,942 Views)
