05-16-2006 09:31 AM
Hello Brad,
No, I don't want a blank SUDialog. I want to save the coordinates that are dispayed in a SUDialog whit a button in a Excel file.
Greetz,
PVH.
05-17-2006 09:29 AM
Hi PVH,
Do you mean 1 pair of cartesian (x, y) coordinates? How will the user be entering those? Should they be separate text boxes or cells in a table? Should they be aligned vertically or horizontally in Excel?
What do these coordinates mean? Why is the user entering them, and how will DIAdem use them in the future?
Brad Turpin
DIAdem Product Support Engineer
05-18-2006 07:47 AM
05-19-2006 11:49 AM
OK PVH,
Here's a good starting application for you, including SUDialog and Excel File state caching.
Let me know if you have questions,
Brad Turpin
05-23-2006 07:24 AM
Hello Brad,
The files you send me are working fine! Now I have another question. Is it possible to realize my project only with DIAdem and not with Excel or any other external program? You mentioned a *.VAS file would be an option.
I tried a few things with a *.VAB file for the different applications. Can I save the .*VAB files somewhere else then in the DIAdem program folder?
Which is the best and easiest path to take, excel or with VAB and VAS files?
Greetz,
PVH. |
05-24-2006 05:12 PM
07-04-2006 01:10 PM
Hello Brad,
I am pretty busy programming at the moment.
A little question:
How can I display continuous, an analog input signal (DAQCard 6024E) in a SUD-Dialog Editbox?
PVH
07-18-2006 10:23 AM
Hi PVH,
This is not an ideal way to use DIAdem. The only way to "continuously" show the values of a file that is being continuously written to, is to create an endless loop in VBScript with a Wait() function and periodically load the data set into DIAdem and display it. There is no real difference in the "continual" displaying of the results in a SUDialog vs. in DIAdem except that it would be much easier to display any results in DIAdem.
You also have to contend with the possibility that whatever program is updating that data file may not like a different application periodically requesting to read from that file.
Good luck,
Brad Turpin
07-20-2006 03:12 PM
How can save a nummeric value displayed in DIAdem-DAC as an variable in a .*VAB file?
Thanks!!
Greetz,
Pvh.
