02-03-2017 06:10 PM
I'm using DIAdem 2014. Previously, when I would double click on a an object in the Report view I would be able to edit it. Now, I just get a cross icon that allows me to move the object but do nothing else. This happens for saved layouts as well as new ones. When I open the same file in DIAdem 2012, I do not have this problem.
I figure I must have accidentally changed some setting, but I can't figure out how to undo it. Any ideas?
Solved! Go to Solution.
02-06-2017 08:28 PM
Does this happen for any report object or is it specific to graphs or tables or images? Additionally, can you still double-click on a view object inside your DIAdem environment and open that property window? It would be interesting to see if this is localized to a certain tab or object type or if it's general to your DIAdem 2014 enviornment as a whole.
02-07-2017 10:38 AM
Hi jordy,
Walter Rick mentioned to me this morning that he remembers there was an issue like this in DIAdem 2014 that was fixed in a subsequent service pack. Can you go to the "Help>>About" menu and tell us the exact version number that you're working with? Or if you remember, just tell us if you've installed a DIAdem 2014 service pack (and if so which one).
Brad Turpin
DIAdem Product Support Engineer
02-07-2017 11:33 AM
This happens to me on text, graph, and table objects - I haven't tried others.
My version information is DIAdem 14.0.0f5641.
02-08-2017 12:42 AM
Hi jordyjordyjordy,
This is version 2014 without service pack. Please can you install the SP1 for DIAdem 2014, which you can download here:
Greetings
Walter
02-13-2017 10:58 AM
Thank you!
