DIAdem
Waveforms operations not working after resampling a channel
I have a very simple script. I would like Diadem to first resample a channel and then work with other channels which are already in waveform.
Call ChnResampleFreqBased("[2]/Zeit [ms]","[2]/Punkt 1.dX [mm]","[2]/Punkt 1.dX [mm]",1e6,"Automatic",0,0)
Call Data.Root.ChannelGroups.Add("Filtered",3).Activate()
Call ChnLinScale("[1]/Extensometer B","[3]/Extensometer B",0.001,0)
 After the channel Extensometer B is scaled and put in the new group it is not waveform anymore but normal numeric channel. When I don't preform the Resample function bofore everything works as expected (ie. it stays as waveform).
Thank you very much for any usefull commnets!
Petr
(3,370 Views)
Hello
I double-checked that, but cannot reproduce it. I used the latest version DIAdem 2015 SP2 for the tests.
Greetings
Walter
(3,352 Views)
I have diadem 2014 and 2015 both 32 bit without any SP. I tried to run the same skript on other computer and I get the same problem. I am using Win 7 professional (64bit) with all the latest updates. I have no idea what the problem might be.
(3,341 Views)
Please, can ceck it with the latest DIAdem 2015 SP2?
You find the installer if you search on NI.COM for "DIAdem 2015 SP2"
Greetings
Walter
(3,339 Views)
