Hello Si Aldworth,
In the DIAdem online help you find the following:
Specifies the name of the current DIAdem Dat data file without the
extension.
Definition |
DataFile, Filename variable |
| Note New loading commands, for example for TDM files, store
the name of the data file in the DataSetName
variable. |
An other way to get that information is to use channel properties as follows:
ChnPropGet("[1]/ChnName", "sourcedatafilename") ' Specifies the filename, if DIAdem loads the channel from a file.
ChnPropGet("[1]/ChnName", "sourcedatafilepath")
' Specifies the file path, if DIAdem loads the channel from a file.
Greetings
Walter
