NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
adek
VBScript continue on new line syntax
Hello there,
As I'm a DIAdem script beginner, I've created a script using the recorder mode, but need to add additional channels to be subracted and to avoid the line becoming to long, want to continue the command on the next line.
Can't seem to find anything referring to multiline syntax in the DIAdem script help - searched the web and found that normal vbscript uses '&_ ' but doesn't seem to work.
Anybody help ?
Regards
AdeK
Active Participant
Twigeater
Re: VBScript continue on new line syntax
Hello AdeK!
Just the _ does the job. The &_ is used if you have a long string and want concat it on multiple lines. No different syntax! & for the string concat _ for the new line!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Member
adek
Hi Matthias,
Tried it and get the warning 'unterminated string constant' after I try running the code, the script screen shows a red squiggle after the _ character in the line code.
Must be doing something else wrong, but note I have to add another 120 channels to this sum ! (I realise there will be a much easier way using some sort of FOR NEXT loop), but I'm just a beginner !
here's the code
ChnCalculate("Ch(""Load Comparison"")=Ch(""Alt Amps"")-(Ch(""Main A"")_
+ch(""Starter A"")+Ch(""DF_1_FUEL_SENS1""))") '... FormulaTxt
Regards
Adrian
Active Participant
Twigeater
Hello AdeK!
You want to spread a string on multiple line than you have to close the string, add a closing ", add a & to concat the two strings and a starting " in the new line.
ChnCalculate("Ch(""Load Comparison"")=Ch(""Alt Amps"")-(Ch(""Main A"")" & _
"+ch(""Starter A"")+Ch(""DF_1_FUEL_SENS1""))") '... FormulaTxt
Conclusion: You have to split the string into two parts, concat them and then you can use the _ to put them on two lines.
Matthias
Matthias Alleweldt
Twigeater?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
