02-24-2015 07:02 PM
I am experiencing a bug in the Report section of DIAdem.
I have ~80 sheets in a report. I delete the last one by right clicking and selecting "Delete". I confirm the deletion when prompted and the sheet goes away. I now press Ctrl-Z to undo the deletion. DIAdem appears to reload the whole set of 80 sheets and the sheet that I deleted is back. The undo function works.
The problem I have now is that I lose the mouse input for the report section and data portal. I am able to change the view to NAVIGATOR, VIEW, etc. with the mouse but I can't click on anything else including the pull-down menus. Keyboard navigation works as I can move around the report and edit Text blocks, etc. but the mouse input is completely gone.
I am using DIAdem 2014 SP1. Can anyone replicate this issue?
Jacob
02-25-2015 04:31 PM
Hi Jacob,
Could you export your DIAdem reports as a .TDR file so we can try it out on another system and see if the problem is reproducable?
