01-25-2007 03:23 PM
01-26-2007 04:59 PM
Hi wenko,
Do you mean that the data is in a binary *.xls file or in an ASCII *.csv or *.txt file? Are you loading the data into DIAdem with the Excel Import Wizard, the ASCII Import Wizard, or with a DataPlugin? In general this should work, but the way to go about it depends on what your data is and how it is coming into DIAdem.
Brad Turpin
DIAdem Product Support Engineer
National Instuments
01-26-2007 11:29 PM - edited 01-26-2007 11:29 PM
Message Edited by wenko on 01-26-2007 11:31 PM
01-29-2007 01:05 PM
Hi wenko,
Because you need to combine your date column and time column, your cleanest solution will be to use either the ASCII or Excel Import Wizard. I took your posted data and turned them into an Excel data file (assuming European D.M.Y formatting) and created an STP file to be used with the Excel Import Wizard. This STP file loads all the columns but also loads an additional column which is just the sum of the Date and Time column. You could alternatively add these channels together yourself in DIAdem after loading.
Ask if you have further questions,
Brad Turpin
01-29-2007 02:10 PM
Hi Brad
I am not sure at the moment how to do this but I will do this on monday next week and if i have problems I will post my troubles.I am in England till Friday.Thank you for your support ,I am happy that oi could display this data in Diadem ,it is quite important for me.Till next week best regards
