10-12-2014 09:04 AM
Hello
i have a Question
how can i displayed in the 2D-Axis the Date and the Time of the Recording?
Now the starttime is always 0, but in realyti its the 8 of octobre 2014 at 08:13.000.
how i can display the corect date and Time?
Thomas
10-13-2014 10:44 AM
Hi Thomas,
In order to display datetime on the axis of a DIAdem graph, you need to use a datetime channel. Do you already have one? Where is that datetime information stored when it loads into the Data Portal-- as a property or a channel or what?
Brad Turpin
DIAdem Product Support Engineer
National Instrruments
10-14-2014 02:42 AM
Hi Thomas,
like Brad has menetioned, DIAdem needs information about the start time.
Are you sure DasyLab stores this information with your data?
Which file format do you use for saving your data?
Kind Regards,
Philipp
AE | NI Germany
10-14-2014 04:57 AM
i have make 3 printscreens from my Dataportal.
When i can give a offset of the Timechanel. i think ist fixed the problem.
and this is the Header
DTDF
ServiceLab [Jun 20 2011]
WORKSHEET =
AUTHOR = Thomas Gull
COMPANY =
DIVISON =
TITLE =
SAMPLE RATE = 15.000000
DATA FORMAT = 1
DATA CHANNELS = 2
START TIME = 12.10.2014 10:10:32
FILE START TIME = 12.10.2014 10:10:32
CHANNEL UNIT:
Generator 0 V
Generator 0 V
10-14-2014 05:35 AM
Hi Thomas,
you are right. The offset property can solve the issue.
But I think this should be done by the dataplugin correctly.
Is this the first time you try to import ddf files?
Regards
Philipp
AE | NI-Germany
10-14-2014 05:44 AM
no
i hav any time importet DDF-Files
but always the same problem
at the first time i have make a new timeline in the Analysis mode.
but i think its not enough easy when i must make any Diagnostics.
thats rigt it must do at the import-sequenze to make the offset automatlicli.
Thomas
10-14-2014 06:28 AM
Hi Thomas,
I haven't seen any of the porperties listed in the header in the channel properties. Perhaps these properties are interpreted as group or file properties.
When you post a file I can try to import the file correctly.
Have you tried to change the regional settings of time format and decimalpoint to solve this issue?
Philipp
AE | NI Germany
10-14-2014 06:38 AM
i dont know where i can change the regional settings
10-14-2014 06:45 AM
in the attach ist the file after the Import
no Corectured time Axis
10-14-2014 06:52 AM
w^hen you need the original DFF
i must sent it otherway its not possible to post is here
