05-24-2016 05:04 AM
Is this the TDM Streaming Library open source to port it to Posix-compatible Operation systems like Linux or QNX?
The goal is to create and record Data Asqusitions in TDMS format under Posix Linux or other Operation Systems.
Thank you.
05-24-2016 06:18 AM
There is no source code available but LabVIEW itself can be used with the native TDMS VIs to measure data on Linux ...
05-24-2016 09:19 AM
Is it possible to open sources of TDM Streaming Library to port and using it in QNX, WxWorks not-Linux OSes?
05-25-2016 01:29 AM
There is a TDMS format description at
http://www.ni.com/white-paper/5696/en/
I assume directly write TDMS is also possible using natvive methods for a single defined measurement task.
