10-31-2015 01:14 PM
Dear users,
I am trying to match the time from a video recording using a high speed camera and data from waveform graphs to show what is happening each frame in the waveform graph. Both video and data from sensors are triggered from the same source. The camera samples at 10 kHz whereas the DAQ at 80 kHz.
I pressed --Video -- Display -- Frequency = 10000 [1/s] and start time 0 [s]. In addition, I have selected the curve cursor to force the graph to go to start. The video with the data are not synchronised as the video ends up quickly whereas the graph does not reach the peak. Any ideas would be appreciated.
Thanks.
Solved! Go to Solution.
11-01-2015 03:12 PM
Hi StathPol,
Check the "Unit" property in the Time channel or the waveform delta x property, whichever you're using. Possibly your sensor values have a "ms" or something for the unit string of the time information.
Brad Turpin
DIAdem Product Support Engineer
11-03-2015 10:40 AM
Hi Brad,
Thank you for your answer. You are right yes, I kept the time as seconds; I changed the frame frequency of the video to 10000 1/s and starting time to 0 as I was doing before and it seems to work with the interpolation method in the x-axis. During the <play> time, is there any way I can save the video with the waveform synchronised with the video to show to presentation as AVI or windows media player?
StathPol
11-04-2015 07:54 AM
Just did it with a different software..THanks Brad
