I am having trouble successfully setting the variable D3CCurveIsoNo via a script. I am using DIAdem 10.0. I am attaching a data file, a REPORT layout and a VBS. Running the VBS will open the file and load the REPORT and try to set D3CCurveIsoNo = 10 for curve 3 which is displaying isolines. I can change this value in the REPORT properties dialog, but I would prefer to change it via a script.
Thank you for your help!
Julia Moeller
