02-18-2015 02:28 AM
I am trying to implement the following:
The user selects a folder (which contains subfolders) in a dialog:
Set Dateiauswahl = CreateObject("Shell.Application").BrowseForFolder(0,"Verzeichnis auswählen",512,mess_path)
Set Ordner = CreateObject("Scripting.FileSystemObject").GetFolder(Dateiauswahl.Self.Path)
All subfolders in the selected folders are listed in two global array variables:
Call GlobalDim("FolderList("&Ordner.SubFolders.Count - 1&")")
Call GlobalDim("FolderPaths("&Ordner.SubFolders.Count - 1&")")
f=0
for each Unterordner in Ordner.SubFolders
FolderList(f) = Unterordner.Name
FolderPaths(f) = Unterordner
f=f+1
next
Later on, only the files from some of the subfolders should be stored in another array FileList:
f=0
for q=0 to UBound(auswahl)
Unterordner = FolderPaths(auswahl(q))
Call MsgBox(Unterordner)
For Each File In Unterordner.Files
if instr(1,File.Name,"Speed")=0 then
FileList(f)= File.Path
f=f+1
end if
Next
next
Now I seem to have a problem with the type of the data that is stored in the FolderPaths array. While Unterordner is a Folder Object, and needs to be a Folder Object for For Each File In Unterordner.Files to work, storing it in the array turns it into a string variable.
I don't really understand why, and am looking for a solution so that I can extract single subfolders from the FolderPaths array and then extract their files.
02-18-2015 03:06 PM
Hi maliya,
In order to assign an object to an array element (or any other variable), you must use the Set syntax, like this:
Set FolderPaths(f) = Unterordner
Then later on you can retrieve it with the same syntax:
Set Unterordner = FolderPaths(auswahl(q))
Brad Turpin
DIAdem Product Support Engineer
02-23-2015 08:26 AM
what i found out is, that the order of the folders sometimes is mess - and i don´t know exactly why or on what the order depents.
it can be that your list is
c:\tmp\2
c:\tmp\1
c:\tmp\6
c:\tmp\3
to get the list in the right order i use a "bubble-sort"........
bubbleSort(Array A)
for (n=A.size; n>1; n=n-1){
for (i=0; i<n-1; i=i+1){
if (A[i] > A[i+1]){ A.swap(i, i+1)
} // ende if
} // ende innere for-Schleife
} // ende äußere for-Schleife
