08-07-2007 08:36 AM
08-08-2007 05:28 AM
08-09-2007 04:13 AM
Hi There,
I'm still a little lost, the GPI variable used by SQL_BindVar can only store a Maximum of 255 characters. How do I get the entire contents of that column which is a string of approx 10000 characters.
S
08-09-2007 06:44 AM
Just to clarify the previous post, I should have said 'field' instead of 'column'.
08-09-2007 10:13 AM
08-13-2007 03:05 AM
Hi James,
I am still not having any success extracting this data. Could you type me up an example so I can insert it into my code and see if it is something silly I am doing here please?
Basically all the code needs to do is to extract a string value value from a single field called 'data' from a table called 'fftx'. I expect that this would be only a few short lines.
S.
08-13-2007 03:19 AM
09-04-2007 05:45 AM
