DIAdem
Report: channel description error in multiple tables
I get several error messages when creating more than one channel table and wanting to display the channel descriptions. Is there something wrong with the assignment of the description value to the header line? I attached a minimum example:
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Call Data.Root.Clear()
Call DataFileLoad("C:\Program Files (x86)\National Instruments\DIAdem 2014\Examples\Data\Example_data.tdm")
Call Report.NewLayout()
Dim oMySheet, oMyTable, oMyColumn, oMyGrp, iCount, gCount
For gCount = 1 To GroupCount
  Set oMyGrp = Data.Root.ChannelGroups(gCount)
  Set oMySheet = Report.Sheets.Add("Table" & gCount)
  Set oMyTable = oMySheet.Objects.Add(eReportObject2DTable,"Table" & gCount)
  oMyTable.Settings.Header.Title2 = "@@Data.Root.ChannelGroups(CurrGroupIdx).Channels(CurrChnNo).Properties("& Chr(34) &"description"& Chr(34) &").Value@@"
  oMyTable.Settings.Header.UseAutoFontSize = TRUE
  oMyTable.Position.ByBorder.Bottom = 5
  oMyTable.Position.ByBorder.Top = 5
  oMyTable.Position.ByBorder.Left = 5
  oMyTable.Position.ByBorder.Right = 5
  For iCount = 1 To oMyGrp.Channels.Count
    Set oMyColumn = oMyTable.Columns.Add(e2DTableColumnChannel)
    oMyColumn.Channel.Reference = oMyGrp.Channels(iCount).GetReference(eRefTypeIndexName)
  Next
Next
Call Report.Refresh()
As you will see, everything works fine for the first table, but errors are produced for all the following ones.
/Phex
Message 1 of 12
(5,546 Views)
Hello Phex,
Your script works fine on my PC. I tested it with DIAdem 2014. What is your version?
Greetings
Walter
Message 2 of 12
(5,540 Views)
It is 14.0.0f5641
The script runs through without interruption, but there are error messages of this kind in the log file:
"The index XX does not match any of the elements in the list."
When opening and closing the properties of a channel table other than the first, a warning message pops up:
"Several errors or warnings have occured.
Check the logfile for details."
Message 3 of 12
(5,536 Views)
Hi Phex,
You're right. I didn't check the log file. It seems that there are some initializations are missing. If you start your script with command to open REPORT first it works well.
call WNDShow("Report", "maximize")
Greetings
Walter
Message 4 of 12
(5,528 Views)
Where exactly did you put "Call WNDShow("Report", "maximize")" in the script ? I tried it with the command right at the beginning but it didn't make any difference.
/Phex
Message 5 of 12
(5,525 Views)
As first command - before the first REPORT command.
Greetings
Walter
Message 6 of 12
(5,523 Views)
Sorry, but that doesn't seem to work for me. Same error messages as before.
/Phex
Message 7 of 12
(5,521 Views)
We need to analyze this more in detail. I created an entry for the developer's.
Greetings
Walter
Message 8 of 12
(5,508 Views)
Hi Phex,
We found the problem. It was a wrong in index in the definition of the column header. Here is the fixed code:
'  oMyTable.Settings.Header.Title2 = "@@Data.Root.ChannelGroups(CurrGroupIdx).Channels(CurrChnNo).Properties("& Chr(34) &"description"& Chr(34) &").Value@@"
    oMyTable.Settings.Header.Title2 = oMyGrp.Channels(iCount).Properties("description").Value
  Next
Next
Report.Refresh
Greetings
Walter
Message 9 of 12
(5,492 Views)
Hi Walter,
thanks for the input. In the meanwhile I found a more versatile solution, which even updates the channel description in the report when it is being changed afterwards by using the ChnComment command:
  oMyTable.Settings.Header.Title2 = "@@ChnComment(CCN)@@"
  Next
Next
Could you please explain why it was not working with my previous code?
 Another example scenario would be if I may want to display the first channel value of each channel:
oMyTable.Settings.Header.Title2 = "@@Data.Root.ChannelGroups(CurrGroupIdx).Channels(CurrChnNo).Values(1)@@"
OR when wanting to show a self-assigned property:
  Call oMyGrp.Channels(iCount).Properties.Add("xyz","abc")
Next
oMyTable.Settings.Header.Title2 = "@@Data.Root.ChannelGroups(CurrGroupIdx).Channels(CurrChnNo).Properties("& Chr(34) &"xyz"& Chr(34) &").Value@@"
These examples produce the same strange behaviour.
The general question would be: How can I display updatable channel properties in REPORT using an object-oriented approach?
/Phex
Message 10 of 12
(5,487 Views)
