02-20-2014 03:11 PM
I have a simple two page report (Find it attached). The second page contains a static text field.
I have s simple script (Find it attached). The script contains a single line: Call Report.Sheets.Copy("Sheet 2","Sheet 3",1) that should copy the second page of my report.
1) I open Diadem, load the report, load the script, run the script. When I look at the reports new page it does not contain the text field that was on the second page of the report.
2) I open Diadem, load the report, switch the report to the second page, switch the report back to the first page, load the script, run the script. When I look at the reports new page it DOES contain the text field that was on the second page of the report.
Why is this?
If I add the following to the script before the copy command: Report.Sheets.Item("SetupSheetTemplate").Activate, then both my above scenarios work.
If I take the new script and attempt to run diadem via LabVIEW (Open DIAdem reference, open report, open script, launch script) I get the same problem where the text field does not appear on the new report page.
Has anyone else seen this?
Thanks for your help
Denis
02-21-2014 06:12 AM
try to use this command:
"call graphsheetcopy(("Sheet 2","Sheet 3",1)".
But your script works correctly on my machine.
Simyfren
02-21-2014 03:01 PM
Hi Denis,
Your script also works correctly on my computer with DIAdem 2012 SP1 and DIAdem 2012 SP2.
Brad Turpin
DIAdem Product Support Engineer
02-24-2014 06:14 AM
Simyfren,
thanks for the suggestion. Using the GraphSheetCopy function solves the problem when working within DIAdem without needing the Report.Sheets.Item("SetupSheetTemplate").Activate
However the problem still exists when running the script.
Denis
02-24-2014 06:16 AM
Brad,
thanks for testing this out. However we are using version 2012 and updating is not a possibility. Could you possibly perform the same test with version 2012?
Thank you for the help
Denis
