08-30-2007 05:24 PM
08-31-2007 01:43 AM
08-31-2007 09:00 AM
Hi jreynolds,
I have a couple of thoughts to add to Ingo's answer. The PNo() function will always return a row, and it will return the closest match to the search value you enter. The Find() function allows you to require an exact match. If there is no match in the channel, the Find() function will return row = 0. You can in both functions specify a start row for the search.
You could alternatively use a Channel Calculator expression to compare multiple rows with one line of code. If you have DIAdem 10.1 or later, you may need to use the ValEqual() function to require an exact match within the resolution of a DBL value.
Ask as you have further questions,
Brad Turpin
DIAdem Product Support Engineer
