DIAdem
Reading sample time of TDM format Measurement data from MATLAB
Hi I am trying to extract sample time from one of the TDM measurement file format using the example file "http://www.ni.com/example/30957/en/". Since i am unable to extract "sample time" in the converted .mat format is there any script needed for this purpose.? or Is there any other way of assigning sample time to the signals in the converted .mat file ?
(4,410 Views)
Hi Dark,
When I try to follow that link you posted, I get an error.  Could you perhaps post the TDM and TDX file you're referring to?  Your only option for saving time information to the converted *.mat file is to put it in a variable-- either a scalar variable with the sampling rate or sampling period or a 1D array variable with all the time values in it.
Brad Turpin
DIAdem Product Support Engineer
(4,332 Views)
hi
here is the link which was used to access dll files for the conversion http://www.ni.com/example/30957/en
(4,304 Views)
