03-24-2006 01:42 PM
03-27-2006 10:39 AM
Hi Andrew,
This application is crying out for the DataFinder. Do you and your users have access to DIAdem 10? If so, then we can offload the channel selection across multiple files to a robust, elegant, and shipping feature. You can also insert your own custom loading methods into the context menu of the ResultsList that displays the channels you searched out in the DataFinder.
If you do need to programmatically load selected channels, the command you want is DataFileLoadSel(), which will use a particular DataPlugin to load a certain subset of channels from one file. You would have to call this command once for each of the files you want to load those channels from. If you're loading all the values of these selected channels, then again this is a built-in feature in DIAdem 10-- all the user has to do is drag the displayed channels they searched out into the DataPortal.
Let us know if you need further help,
Brad Turpin
DIAdem Product Support Engineer
03-27-2006 12:46 PM
Thanks Brad. I do have access to DIAdem 10 but my users do not as of right now. I hope they will in the near future. The DataFileLoadSel() worked great but I need to be able to select the channels I want to load. I still need to create a list of channel names that the user can select from so only those channels can be loaded. I will post another question on the board about that since it is a new topic.
AJL
