DIAdem
Reading TDM/TDX files from PHP5
Did someone know if a library exist to read a TDM and TDX file from PHP?
I would like to plot som data from a TDM file on a webpage. The web server is running on Linux...
Yannick
(3,436 Views)
This might not be trivial. The TDM (XML-based) file uses several advanced XML techniques, so you'll need at least XPath in order to address objects in the file. Furthermore, you will need to gather information from different objects that are invisible in the user interfaces of DIAdem and LabVIEW. Not sure if they're documented. A proper description might be up on www.asam.org, but it is not going to be fun to read 😉
I have tried to use XSLT to publish hierarchy and properties of a TDM file as HTML, but gave up on it since handling of the # pointers was a nightmare.
I'd love to hear about a successful approach.
Herbert
(3,433 Views)
