Hi Oriol,
You can use the following syntax:
' opens dialog for path and file name setting
if FileNameGet("ANY", "FileWrite", "D:\Test\", "PDF file (*.PDF),*.PDF") = "IDOk" then
' msgbox FileDlgFileName
PrintName = "winspool,DIAdem PDF Export,LPT1:"
PDFFilename=FileDlgFileName
PrintRangeType = "PageEnums"
PrintFromPage = 2
PrintToPage = 4
Call PicPrintDlg("WinPrint") ' opens dialog for PDF parameter setting
'Call PicPrint("WinPrint")
end ifGreetings
Walter
