07-24-2017 06:59 PM
I have 3 test systems, 2 that have been working for over a year. A third test system is being built. The first to automatically load correctly. The third has the following problem.
I am using a template to save a PDF. The data is from a tdms file. When the file is loaded the block shows "NOVAL" If I open the editor and press check I get NOVAL, then I just highlight the target on the right side that matches the editor target. Then press check I get the value.
07-25-2017 01:57 PM
Hi Dfjjbn,
Would you mind attaching some screenshots of the behavior? I would be interested in attempting to reproduce this on our end.
In addition, which software versions are you using?
