04-26-2012 04:19 AM
HI everyone,
I have been trying to get the opposite value of a binary channel using NOT function and i don't get the right values.
i'm extracting bits from a word with GetB
then i have to use CTNV to clean the NOVALUE data because of the malfunction of the GetB (already corrected for Diadem 2012 but not for my 10.2)
and at last i will like to get the invert value so: 0 will be 1 and 1 will be 0
These is the code that i'm using and the results:
Call ChnCalculate("Ch(""[1]/CHFS Bit 0"")=GetB(Ch(""[1]/CH 2 CHFS""),0)")
Call ChnCalculate("Ch(""[1]/CHFS Bit 0"")=Ch(""[1]/CHFS Bit 0"")+CTNV(Ch(""[1]/CHFS Bit 0"")>1)")
Call ChnCalculate("Ch(""[1]/CHFS Bit 0_a"")=NOT (Ch(""[1]/CHFS Bit 0""))")
Results:
1 = -2
0 = -1
i can correct with an offset but will be more time for process the data... and if is a malfunction like in GetB is important to correct too...
I'm doing something wrong or is a real malfunction ?
Thanks in advance
Rafael
Solved! Go to Solution.
04-26-2012 12:43 PM
Hello Rafael,
the problem here is the assumtion that true is equal 1.
This is not true. In VB true is -1 and in general there is only one real assumtion for bool true which is "true is not false".
MsgBox CInt(true)
==> -1
MsgBox CInt(false)
==> 0
So after changing your formula to
Call ChnCalculate("Ch(""[1]/CHFS Bit 0_a"")=NOT CBool((Ch(""[1]/CHFS Bit 0"")))")
Your results will go to 0 and -1 which is true and false.
But now your case. Why does NOT 1 result in -2.
Thats easy because its a logical operation to every single bit in the integer number
1 = 00000000000000000000000000000001 -2 = 11111111111111111111111111111110
You can validate this with the Programmer View of Microsfts calc.exe
NOT 1 also results in -2
So everything is working well. Even if its a little bit unexpected.
Call ChnCalculate("Ch(""[1]/CHFS Bit 0_a"")=Abs(NOT CBool((Ch(""[1]/CHFS Bit 0""))))")
Results in what you want.
greetings from rainy germany
Andreas
04-27-2012 01:27 AM
I love this Forum....
THANKS a lot for the explanation, i understood perfect, and thanks for the solution too.
I didn't know about the VB true is -1
Until next time.
Rafael
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
