11-07-2016 09:20 AM
You can either load all search results
Navigator.LoadData(Navigator.Display.CurrDataFinder.ResultsList.ResultsElements)
or only the selected result elements
Navigator.LoadData(Navigator.Display.CurrDataFinder.ResultsList.Selection)
Hope that helps.
11-07-2016 09:51 AM
LoadData on the full element list still throws an error but you can load them individually inside a for loop.
Thanks, that should get me going.
11-08-2016 09:08 AM
Hi Denis,
When was the last time you updated your DEWESoft DataPlugin? I seem to recall that loading multiple files was a bug in that DataPlugin that got fixed a little bit ago.
Brad Turpin
DIAdem Product Support Engineer
11-08-2016 09:17 AM
Hi Denis,
I spoke to quickly. This issue was reported and investigated, and the problem is that the DEWESoft API can only open one file at a time. Our DataPlugin uses that API and has no way around this limitation.
Keep using the workaround,
Brad Turpin
08-17-2020 09:43 AM
Does the DataPlugin work on newer *.dxd files from Dewesoft X daq sw?
08-19-2020 04:28 PM
Hi tuntugacho,
The download site for the DataPlugin says it works with *.dxd files, but that the DataPlugin was last updated on March 12, 2018. If there are significant changes to the disk footprint encoding of *.dxd files that have happened since then, then it's possible the DataPlugin won't react properly to those files.
Could you post a few *.dxd files that give you trouble in DIAdem? Or email them to me at brad.turpin@ni.com.
Brad Turpin
Principal Technical Support Engineer
NI
