02-06-2015 11:35 AM
Greetings:
I have a test run that has a Trigger pulse. It repeats thousands of times depending on the test run.
I need to measure ( in my example) the “Velocity FDBK” Average and compare it to the “Velocity CMD” Average signal. I would like to be able to create a channel for the measurement results for each cycle that the pulse is active.
This is my attempt at the script, but I am having trouble with the looping.
I welcome any help ….please.
Thanks Spidey
Solved! Go to Solution.
02-18-2015 09:53 AM
Hi Spidey,
which dataplugin do you use to import your file?
Which looping do you mean exactly?
Kind Regards,
Philipp
02-18-2015 10:08 AM
Philipp:
Thank you for your interest in my problem. With the help of a fellow colleague we have solved my problem.
I was using a Astromed file (.DCR) . The looping was the signal measurements within the timing "Pulse".
Thanks 🙂
Spidey
