05-18-2006 02:59 PM
05-18-2006 04:19 PM
Hi Julia,
Maybe you find the solution for that in the properties of „My DataFinder“.
If you are in the properties dialog please select the tab “DataFinder” and verify whether the checkbox of your DataPlugin is set.
We don’t set it per default because otherwise the DataFinder would start crawling to index all files with the extension of your new DataPlugin immediately. And sometimes it make sense to have a look at the new DataPlugin before finally use it.
I hope this will solve the problem.
Greetings
Walter
05-19-2006 09:04 AM
Thank you Walter! This appears to work now. My ".usg" files still have question-mark icons next to them, as the data finder indexes these files, will the question marks go away?
05-19-2006 09:10 AM
Hi Julia,
Yes, but you may have to force the re-indexing of those files by removing the Search Area and adding it back (or removing the files and adding them back). You may even need to kick off a manual re-index from the DataFinder properties dialog under the "Indexer" tab. But then the question mark should go away.
Let us know if you still have trouble,
Brad Turpin
DIAdem Product Support Engineer
