Hi Anna,
You didn't mention which DIAdem version you are now using, or are you still using DIAdem 8.0? In later versions there is a nice CSV export feature in DIAdem, but I'm attaching below an example of how to export to a .DAT file where the values are stored in a text file instead of a binary file. This was the old way of doing ASCII export. It's quite fast, but it doesn't add any header lines at the top. The VBScript attached below has an optional section which shows how to programmatically rewrite the file so that there are a few header lines, in case you want them.
Brad Turpin
DIAdem Product Support Engineer
