11-07-2007 10:30 AM
11-07-2007 10:58 AM
11-07-2007 01:23 PM
Hello FHM!
If you use DIAdem 10 or better there is another aproach: Use an expression like '@T1@' as filename in the report and just set the variable to your image filename und call 'PicUpdate'. The advanced user can use an expression like '@@MyCmdExtFunc@@' as filename to implement a dynamic call to an user command extension script function on every 'PicUpdate'.
Matthias
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
11-08-2007 03:02 AM
