The current ISO/TS 13499:2001 is called MME format, Multimedia data exchange format for impact tests. It is the updated version of the ISO draft from 1996 which is called EGV format. There is no other update of EGV.
For using DIAdem please look to www.ni.com/dataplugins. You will find a free file import filter download for MME and EGV. The import filters are written in VBScript and you can adapt them if you need derivations from the standard.
The mapping of EGV to DIAdem has not changed for the GPI import . The GPI-DLL egvload.dll still work like it is described in the document you mentioned.
The data plugins make use of DIAdem 9.1 features like custom properties and channel groups. Therefore the DIAdem mapping is different to the older GPI imports.
