02-22-2006 08:51 AM
Thing is that in DIAdem I have a main SUD dialog, from this I open another dialog, from which I would like to read some object properties from the main dialog…
Is that possible? If yes, how can I do it?
Thanks in advance,
Marc.
02-22-2006 12:00 PM
02-23-2006 05:53 AM
Thanks for the information and one more question:
It's possible to hide the main dialog or to move it to another screen position when the child dialog is open?
Marc.
02-23-2006 07:58 AM
02-23-2006 10:22 AM
Hello Marc,
each SUD-Dialog has its own script-engine. So you can only access variables or objects when running its Dialog (its script engine). Changing data between dialogs (also changing data between DIAdem and dialogs) is only possible by using DIAdem-Variables (pre-defined like L1, user-defined in a vas-file or dynamic DIAdem variables). You know it for sure.
There are ten DIAdem variables named o1 .. o10 with the type 'variant'. You can store script objects in this variables. Using this DIAdem variables you can change objects between several script engines: DIAdem to dialog or what you want: dialog to dialog.
Example:
Bevor you start the second Dialog:
set o1 = editBox1
sudDlgShow ...
In the second Dialog you can access the editBox from the first dialog:
msgbox o1.text
02-23-2006 10:26 AM
Sorry but this doesn't work, we are talking about DIAdem and a SUD dialogs...
I found how to move the dialog, using the Left and Top properties and also with these properties you can move the dialog out of the screen that is almost the same than to hide it… there is any other way to hide the dialog?
The properties Left and Top are available on DIAdem 9.1 but not on DIAdem 8.1 dialogs, does any one know how to move or to hide a dialog with that version?
Marc.
02-23-2006 11:32 AM
Andreas,
That works, you are a genius...
Sorry to continue bugging you, but I have more questions. As you said it’s necessary a DIAdem-Variable, then my question is:
It’s possible to create a variant DIAdem variable in a VAS file? There is any other way?
In DIAdem 9.1 we can use o1...o10 variables, but how I can do that in DIAdem 8.1?
I know it’s a crap but my code has to work with booth versions… :((
Marc.
02-27-2006 03:59 AM
Hello Marc
Update! Sorry, but it dont work. You can not store dialog-controls into the o1 variable. It words only once. The second time, i store a control in this variable an error occured. I must restart DIAdem bevor i can use the variable o1 again. Dont know the reason.
You can not create a variant-variable in a VAS-file. In DIAdem 9 you can create a DIAdem-variant-variable using the command "globalDim".
The o-variables and the command "globalDim" are features in version 9 of DIAdem. It will not work with DD8.
I see no simple way to solve your problem (working with DIAdem 8 and 9). You must sore each data in its own variable or use a self-defined object structure to do this.
sorry, hope it helps
02-27-2006 09:02 AM
Hi Andreas,
I see the problem, any way thanks for your interest. Finally I will store all needed information fom the dialogs into my own DIAdem variables. That will be also very useful for me because I have to close the dialog and to open it again with the previous information in order to activate the interaction mode, that is not possible while the dialog is active.
Marc.
