DIAdem
Is it better to convert from a database to TDMS, for analysis in Diadem?
I have a database (sample attached, mdf sql server localdb ) file (170 mb max)  and would like to analyse it in Diadem.  What is the best way? One thought is to create a Labview exe converter (mdf to tdms). What do you suggest? Thanks.
database
https://www.dropbox.com/s/eb3cydanshrokx3/M2004%202013_04_18%2013_22_16%20WNM-6141-MG_Post.zip?dl=0
An example of our data
The two Definitions above are known/fixed.
[Log Event Definition] below
Event Name        Event Number
Flow Evt               0
DirSnsr Evt           1
Pulse Evt              2
Gamma Evt         3
Vibration Evt       4
Temperature Evt               5
Power Evt            6
Extreme Vib Evt 7
Extreme Shock Evt           8
Config Change Evt            9
Set Time Evt        10
Reset Evt             11
Snsr Com Evt      12
PC Com Evt         13
Int FLASH Evt      14
Int EEPROM Evt 15
INA Evt  16
EM Pulse Evt       17
Tilt Snsr Evt         18
[Log Field Definition] 145 lines; removing seconds, ms about 130
Event Number    Field Name          Field Index           Unit       Format  Offset From Last               Byte Offset               Bit Offset             Element Length  Raw Datatype    Scale      Offset
0             Seconds               0                            Time      1             0             0             32           1             1             0
0             Milliseconds        1                            TimeOffset%0.3f              1             0             0             16           2               0.001     0
0             Flow      2                            %d          1             0             0             8             0             1             0
0             Temp     3             °C           %d          1             0             0             8             2             1             30
0             Flow Confirm Dly              4             secs       %d          1             0             0             8             2             1               0
Rest in the attachement. Ignore the size mentioned in the docx
(5,977 Views)
You can use the database toolkit in LabVIEW to fetch data from database and then save as TDMS file that is readable for DIAdem.
(5,961 Views)
ADO itself can potentially be used to access the data from DIAdem. The following script can be used to create the ADO connection string.
Option Explicit
ADOConStrGet() msgbox AdoConString
 potentially your script will somehow look like this one
option explicit
dim mdfFile : mdfFile = "C:\temp\MyDataBaseFile.mdf"
dim conStr : conStr = "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Data Source=localhost;Initial File Name=" & mdfFile
dim ado : Set ado = CreateObject("ADODB.Connection")
ado.Open conStr
dim getResult : set getResult = ado.execute("SELECT * from [MyTableName];")
dim chNames : chNames = Array : redim chNames(getResult.Fields.count - 1)
dim i : for i = 1 to getResult.Fields.count
  chNames(i - 1) = getResult.Fields.Item(i - 1).name
Next
dim rowVals : rowVals = getResult.GetRows(-1, 0, chNames)
data.root.Clear
ArrayToChannels rowVals, chNames
 Afterwards the result of your select command can be found in DIAdem channels.
(5,922 Views)
Thanks. guys. The AE suggested VBS DataPlugins too. So what is the best way? I need to create an exe out of the converter and it needs to be efficient.
I appreciate your help.
(5,899 Views)
Hi pavan_b,
If you need a converter that runs as an *.exe, then you should probably go the LabVIEW DataBase Connectivity Toolkit route.  A VBScript DataPlugin would have to use ADO commands the same as a DIAdem VBScript, only it would be constrained to load the whole data base at once, which could easily be too much.  Using a LabVIEW *.exe to send the data base records to multiple TDMS files sounds like the right approach.
Brad Turpin
DIAdem Product Support Engineer
(5,873 Views)
Thanks Brad. I thought what the AE suggested was a little off but email communication doesn't help either.
(5,867 Views)
