DIAdem
Interface Diadem with Bessler Camera
Dear NI
I ahve a bessler Network camera which can take the pictures and send it to the network using ethernet interface I can see it in pylon viewer .
I want to know that in Diadem can I interface the real camera and analyze it on real time ?
Threre was a example in the tutorial in which a car is moving and its data is analyzed but it was recorded movie can i interface real devise and get its data real time??
rupesh
IIT delhi
(4,762 Views)
Hey rupesh,
What sort of image analysis are you wanting to do?  Most of NI's image analysis capability is in the IMAQ line of products, which also interface with frame grabbing cameras.  It is possible that DIAdem might be able to connect to your camera, but I'm not yet convinced DIAdem is the right tool to run the analysis.  What interface does your camera use (PCI, USB, serial, etc.)?  What is the model number of that camera?
Brad Turpin
DIAdem Product Support Engineer
(4,755 Views)
Thanks for reply
actually I am using Diadem to interface Basler camra . it is a type of camera which directly connects to the computer via ethernet interface and sends us the streaming video which can be viewed using pylon viewer . There is  an example in the file SafetyTest.tdm in which  the file is located in " C:\Program Files\National Instruments\DIAdem 2011\Examples\Data"  in which a video is synchronized with the crash analysys data .
Actually in this example we browse the video and load the data . instead of loading the video file is it possible can i directly stream the video on the view area of the diadem
The Basler camera uses ethernet port of the PC for interfaceit directly streams video to pylon viewer(it is a GUI which comes with the camera)
rupesh
IIT delhi india
(4,748 Views)
Hi Rupesh,
The Video synchronization display in VIEW only works on an existing video file and was designed for post-acquisition display only.
Brad Turpin
(4,736 Views)
Dear Brad,
Thanks for reply , As now It is clear that NI DIAdem is post analysys software we can not directly interface the Basler camera , you have suggested NI MAQ series of proucts , I ahve gone through the link
http://zone.ni.com/devzone/cda/epd/p/id/5030
which shows the  NI-IMAQ for USB Cameras
(4,726 Views)
Dear Brad ,
As Diadem does not support the real streaming of data  and you have suggested IMAQ
I have gone through the link
but the problem is that they support the usb interface  , we need to interface Basler camera which is ethernet based to directly stream to the software
can you suggest some software that can solve my purpose to see the direct stream video using Basler camera two at atime
regards,
rupesh
IIT delhi
(4,722 Views)
Hi Rupesh -
We could make suggestions, but this particular board contains experts and users of the DIAdem software and not IMAQ.  The experts can be found on our "Vision" board of this forum, at the following link - please try your post on that thread.
http://forums.ni.com/t5/Machine-Vision/bd-p/200
Derrick S.
Product Manager
NI DIAdem
(4,717 Views)
