01-06-2015 10:43 AM
I'm trying to import a binary file into DIAdem but I can't figure out how. Please help. I wanted to attach an example binary file but the forum won't allow it. I am attaching a text file with what the data should look like when the binary file is converted. Thanks.
01-07-2015 10:25 AM
Hi stein,
You can post the data file if you zip it first, but you'll also need to post an exact file format description. In order to read the binary file into DIAdem, we'll need to create a DataPlugin that knows how the data is stored in the binary file.
Brad Turpin
DIAdem Product Support Engineer
01-12-2015 10:20 AM
I don't know the exact format of how the file is set up but I am attaching a VI we use to convert the binary to a .txt file. Please let me know if you need anything else.
01-13-2015 01:00 PM
Hi stein,
Given that you already have a VI to read the binary file, and that it appears to be stored as a collection of LabVIEW clusters, I'd recommend that you use the LabVIEW DataPlugin SDK to turn your existing VI into a LabVIEW DataPlugin.
http://www.ni.com/example/31016/en/
Brad Turpin
01-13-2015 05:12 PM
How much of Labview do I need to know to create the plug in? Is there something that can convert the VI to a plugin to use for DIAdem? I'm not very well versed in Labview. Thanks.
01-14-2015 10:52 AM
I'm not a programmer and am very green when it comes to writing code. Is there anyway I can get a plugin created for reading the binary file? Thanks.
