DIAdem
Import txt file into report
I have an Arinc signal that I have decoded into each of its digital I/Os.  Since I have over 150 I/Os I needed a way to sort and do a quick report on them.
I have three categories.
1. Stayed =1 throughout test
2. Stayed = 0 throughout test
3. Changed either from 0 --> 1 or 1-->0 during the test.
I want to just put a list of the signals for each of these categories into my report.
I have created a txt file for these to go in, but how do I import that into my report?
Or is there an easier way?
Here is an example of my code...
'HCM1
'HCM1 Label 104 decode - Untitled 3
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_HSOV_A1_CLOSED"")= GetB (Ch(""[1]/Untitled 3""),0)")
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_HSOV_A2_CLOSED"")= GetB (Ch(""[1]/Untitled 3""),1)")
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_HPP_A_RUNNING"")= GetB (Ch(""[1]/Untitled 3""),2)")
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_SYS_A_HI_TEMP"")= GetB (Ch(""[1]/Untitled 3""),4)")
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_SYS_A_LO_PRS"")= GetB (Ch(""[1]/Untitled 3""),7)")
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_HPP_A_LO_PRS"")= GetB (Ch(""[1]/Untitled 3""),12)")
Call Calculate ("Ch(""HCM1_104/HCM_1_CAS_HPP_A_HI_TEMP"")= GetB (Ch(""[1]/Untitled 3""),13)")
'HCM1 Label 105 decode - Untitled 4
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_HSOV_A1_FAIL"")= GetB (Ch(""[1]/Untitled 4""),0)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_HSOV_A2_FAIL"")= GetB (Ch(""[1]/Untitled 4""),1)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_EDP_A1_FAIL"")= GetB (Ch(""[1]/Untitled 4""),2)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_EDP_A2_FAIL"")= GetB (Ch(""[1]/Untitled 4""),3)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_SYS_A_PRS_FLT_CLG"")= GetB (Ch(""[1]/Untitled 4""),6)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_SYS_A_RET_FLT_CLG"")= GetB (Ch(""[1]/Untitled 4""),7)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_EDP_A1_FLT_CLG"")= GetB (Ch(""[1]/Untitled 4""),8)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_EDP_A2_FLT_CLG"")= GetB (Ch(""[1]/Untitled 4""),9)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_HPP_A_LO_QTY"")= GetB (Ch(""[1]/Untitled 4""),11)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_HPP_A_FAIL"")= GetB (Ch(""[1]/Untitled 4""),12)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_HPP_A_CDF_FLT_CLG"")= GetB (Ch(""[1]/Untitled 4""),14)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_IV_A_FAIL"")= GetB (Ch(""[1]/Untitled 4""),15)")
Call Calculate ("Ch(""HCM1_105/HCM_1_FLT_IV_A_FAIL_LOCAL"")= GetB (Ch(""[1]/Untitled 4""),16)")
'HCM1 Label 106 decode - Untitled 5
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_SYS_A_PF_DPI_FAIL"")= GetB (Ch(""[1]/Untitled 5""),0)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_SYS_A_RF_DPI_FAIL"")= GetB (Ch(""[1]/Untitled 5""),1)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_EDP_A1_CDF_DPI_FAIL"")= GetB (Ch(""[1]/Untitled 5""),2)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_EDP_A2_CDF_DPI_FAIL"")= GetB (Ch(""[1]/Untitled 5""),3)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_EDP_A1_PS_FAIL"")= GetB (Ch(""[1]/Untitled 5""),4)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_EDP_A2_PS_FAIL"")= GetB (Ch(""[1]/Untitled 5""),5)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_SYS_A_PX_FAIL"")= GetB (Ch(""[1]/Untitled 5""),6)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_SYS_A_TX_FAIL"")= GetB (Ch(""[1]/Untitled 5""),7)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_SYS_A_QX_FAIL"")= GetB (Ch(""[1]/Untitled 5""),8)")
Call Calculate ("Ch(""HCM1_106/HCM_1_HSOV_A1_IND_FAIL"")= GetB (Ch(""[1]/Untitled 5""),10)")
Call Calculate ("Ch(""HCM1_106/HCM_1_HSOV_A2_IND_FAIL"")= GetB (Ch(""[1]/Untitled 5""),11)")
Call Calculate ("Ch(""HCM1_106/HCM_1_EDP_A1_FAIL"")= GetB (Ch(""[1]/Untitled 5""),12)")
Call Calculate ("Ch(""HCM1_106/HCM_1_EDP_A2_FAIL"")= GetB (Ch(""[1]/Untitled 5""),13)")
Call Calculate ("Ch(""HCM1_106/HCM_1_FLT_FV_A_FAIL"")= GetB (Ch(""[1]/Untitled 5""),14)")
Call Calculate ("Ch(""HCM1_106/HCM_1_HSOV_A1_RELAY_FAIL"")= GetB (Ch(""[1]/Untitled 5""),15)")
Call Calculate ("Ch(""HCM1_106/HCM_1_HSOV_A2_RELAY_FAIL"")= GetB (Ch(""[1]/Untitled 5""),16)")
Dim k, m, pMyChn, result, ArincTrue, intMyHandle01, intMyHandle02,intMyHandle03,intMyText, intMyError01, intMyError02, intMyError03
    intMyHandle01 = TextFileOpen("C:\ArincTrue.txt",tfCreate or tfWrite)
    intMyHandle02 = TextFileOpen("C:\ArincFalse.txt",tfCreate or tfWrite)
    intMyHandle03 = TextFileOpen("C:\ArincChange.txt",tfCreate or tfWrite)
    For k = 2 to 4
  For m = 1 to GroupChnCount(k)
Set pMyChn = Data.Root.ChannelGroups(k).Channels(m)
    Result = ChnValMax(pMyChn)-ChnValMin(pMyChn)
    If Result = 0 and ChnValMax(pMyChn) > 0 then
    intMyText= TextfileWriteLn(intMyHandle01, pMyChn.Name)
    elseif result= 0 and ChnValMax(PMyChn) = 0 then
    intMyText= TextfileWriteLn(intMyHandle02, pMyChn.Name)
    else
    intMyText= TextfileWriteLn(intMyHandle03, pMyChn.Name)
    End If
  Next
Next
intMyError01 = TextFileClose(intMyHandle01)
intMyError02 = TextFileClose(intMyHandle02)
intMyError03 = TextFileClose(intMyHandle03)
(5,370 Views)
Accepted by topic author 2Pale4TX
Hi 2Pale4TX,
You can't easily reference the content of an ASCII file.  Instead, I suggest you make a new Group of 3 text channels that you can drag onto a REPORT table.
Dim k, m, z, ResultsGroup, TrueChannel, FalseChannel, ChangeChannel, Group, Channel, Result
Set ResultsGroup = Data.Root.ChannelGroups.Add("Results")
Set TrueChannel = ResultsGroup.Channels.Add("ArincTrue", DataTypeString)
Set FalseChannel = ResultsGroup.Channels.Add("ArincFalse", DataTypeString)
Set ChangeChannel = ResultsGroup.Channels.Add("ArincChange", DataTypeString)
For k = 2 to 4
  Set Group = Data.Root.ChannelGroups(k)
  For m = 1 to Group.Channels.Count
    Set Channel = Group.Channels(m)
    ChMax = CMax(Channel)
    ChMin = CMin(Channel)
    Result = ChMax - ChMin
    If Result = 0 and ChMax > 0 Then
      z = TrueChannel.Size + 1
      TrueChannel(z) = Channel.Name
    Elseif Result = 0 and ChMax = 0 Then
      z = FalseChannel.Size + 1
      FalseChannel(z) = Channel.Name
    Else
      z = ChangeChannel.Size + 1
      ChangeChannel(z) = Channel.Name
    End If
  Next ' m
Next ' k
Brad Turpin
DIAdem Product Support Engineer
(5,340 Views)
Thanks Brad!
Works great.
(5,321 Views)
