05-23-2007 02:20 AM
05-23-2007 10:33 AM
Hello siipo,
Is there any documentation available which describes the file format ? Which application creates it ?
It would be helpful to have more than one file to double check which parts of the file are the same for all files.
E.g. Is the channel information always available for 15 channels, even if there are less channels containing data ?
Is the layout of the file header always the same ?
If you could provide some more information it would be easier to help with the plugin.
Andreas
05-24-2007 07:39 AM
05-24-2007 09:03 AM
Hello siipo,
Please copy the attached file to your machine, unzip it and double click the .uri file. You should then have a DataPlugin attached to the .mev file extension. It worked with the files you sent me. Please let me know how it goes.
Andreas
05-24-2007 09:26 AM
05-24-2007 09:41 AM
Hello siipo,
Please try out the attached plugin which should work with your version of DIAdem.
Andreas
05-24-2007 10:10 AM
05-24-2007 10:13 AM
Siipo,
I do have a question regarding the plugin which I'd like to discuss with you offline. Would you mind to send me your contact info to andreasDOThaubATniDOTcom ?
Andreas
