08-12-2015 09:18 AM
Have tried looking around commands and discussions, but i haven't found anything on this so far.
I am looking to form a script around the basis of selecting a certain data channel in the NAVIGATOR window, then hitting say F3 to run a script that will take the names of the highlighted channels and recognize them, is this possible?
Any hints would be appreciated, thank you in advance!
08-13-2015 12:48 PM
Hi Aryk,
If you mean making channel selections in the Browser of the NAVIGATOR panel, here's a good start for you:
Set DataFinder = Navigator.Display.CurrDataFinder() Set Selection = DataFinder.Browser.SelectedElements jMax = Selection.Count ReDim FilePaths(jMax) ReDim GroupNames(jMax) ReDim ChanNames(jMax) For j = 1 TO jMax IF Selection(j).IsKindOf(eSearchChannel) THEN k = k + 1 FilePaths(k) = Selection(j).ChannelGroup.Root.Properties("FullPath").Value GroupNames(k) = Selection(j).ChannelGroup.Name ChanNames(k) = Selection(j).Name END IF NEXT ' j MsgBox Join(FilePaths, vbCRLF) MsgBox Join(GroupNames,vbCRLF) MsgBox Join(ChanNames, vbCRLF)
Brad Turpin
DIAdem Product Support Engineer
