DIAdem
I want to add indiviual values to the end of an existing channel
I have a program the calulates several values from my data and want to write each one sequentialy into a new channel that I have created.  How do I assign a value to the end of a channel?
(5,115 Views)
Accepted by topic author BESandford
Option Explicit
dim chObj : set chObj = data.Root.ChannelGroups.Add("Target").Channels.Add("Target",DataTypeChnFloat64)
' OPTIONAL: channel will automatically grow. To speed this up it is possible to reserve before start
chObj.ReservedSize = 1000
call AppendValue(chObj, 1.0)
call AppendValue(chObj, 2.0)
call AppendValue(chObj, 3.0)
call AppendValue(chObj, 4.0)
call AppendValue(chObj, 5.0)
Sub AppendValue(chObj, newVal)
  chObj.Values(chObj.Size + 1) = newVal
end Sub
Channel grows automatically. Be aware that it might be useful to use ReservedSize property if you can assume how long the channel will be.
(5,099 Views)
Thank you that is exactly what I needed
(5,095 Views)
