Hi Siipo,
We found the problem. The reason depends on the scaling in very special cases. If you have a 2D axis system in VIEW and set the "n-systems" mode for it and then it could happen that the scaling was not correct calculated if the channel values are very different. If tested this behavior on 5 different PC's. On 2 I could reproduce it on 3 not. Attached you find the "repaired" VIEW layout in which just changed the "n-system" mode into "1 system".
Additional I've tested it in DIAdem 10 and it was not problem to load your original layout. The developer told me that they changed some test routines so that it works fine.
Greetings
Walter
