02-28-2008 08:06 AM
02-29-2008 03:56 AM
When you select your DAC Module and here in menu settings the point circuit diagram - then you set the point "before measurement" the command Call WndShow("REPORT","MAXIMIZE") - now when you start measurment you see the REPORT Module. When you click in the report you the the visual or when click (double) again you see the dac scheme - so like my screenshots attached here in *.doc
Best Regards
02-29-2008 03:57 AM
02-29-2008 04:14 AM
02-29-2008 08:57 AM
Hello again Johann.Wagner,
i hope you can help me one more time. If the Report is show, i can´t use the red stop button to end the measurement, and by pressing "ESC", as you wrote, the script also terminates instead of running to its end. How can i change this behaviour?
thanks
diademi
02-29-2008 09:10 AM
02-29-2008 09:15 AM
03-04-2008 02:43 AM
