04-11-2015 09:33 AM
I am building a script dialog box that allows the user to select concatenated channels to preview before loading the entire data set.
Ultimately I would like the previewed channels to come from the most recent test.
I found the "List Folder" option in labview that lists the names of the folders in the current root directory, but would then have to pass the string array to diadem. Is there a similar "List Folder" command in diadem, in which I can get the folder names, particularily the most recent folder name?
I apologize if an answer to this has already been posted...
04-13-2015 06:07 PM
Hi BG103,
The link below is to the Diadem Help document about the Folder object:
http://zone.ni.com/reference/en-XX/help/370859J-01/scripting/objects/scripting_objects_ifolder/
One of the properties you can access with this object is the SubFolders contained in that folder. I believe this may be what you are looking for!
