Thank you for your suggestions. In reality I don't know the names of all the objects in the DAC as this program enables people to setup a custom DAC as part of a larger template. What names they choose will be relatively unavailable to me.
Also, I need to, in the end, enable this to work with not only the English version of DIAdem, but also the German version. Unfortunately, each uses different default names for items in the DAC, further complicating my situation.
I have also discovered that going through the DAC as if it were an ascii file does work, although had not discovered it until after I posted this. (I left it up, hoping there might have been a more offical solution).
Thanks again for your help,
Luke
