DIAdem
How to lock a sheet of report to avoid data changes?
I'm looking for a way to lock a sheet to avoid data changes while the script is loading other TDMS file.
Being clearer: I have a layout which I fill it with data from TDMS file by script but it needs to close and open some TDMS file but I do not want to change some sheets previously filled in with other TDMS file data after I close it and open another TDMS file.
Does someone know?
(3,076 Views)
As far as i know, each object (including plot and report object) only has a reference to the root data / channels, it's not a copy of the data and so you can't lock (save) the data of the object directly, so if you change/reload channels the data is loss. Possiblities to keep data are:
1) export the report
2) use a self defined copy (part) of the read out data to store the data you want to plot. You can do this by using global variables or a data object, e.g.
oCGPlot.Channels("Channelname").Values = oCGData.Root.ActiveChannelGroup.Channels(...).Values
(3,044 Views)
Accepted by topic author clebermarques
Hi clebermarques,
olhass is correct, the REPORT panel graphs and tables, etc. reference the data in the Data Portal.  This is a feature that enables you to re-use a defined REPORT layout (*.tdr file) with different data sets.  You have two options to achieve multiple REPORT sheets that show data from multiple data files:
1) Save each REPORT sheet separately.  You can export an image file from the REPORT panel for each data file that you load.  You can also append a REPORT sheet to an existing PDF file.
2) Simply load multiple data files into the Data Portal at the same time.  There's nothing keeping you from having REPORT sheet 2 reference the data in Group 2 of the Data Portal, etc.  If you want to use the same *.tdr file for each data file, I can help you with a script that will point the graphs and tables, etc. to the desired Group in the Data Portal.
Brad Turpin
DIAdem Product Support Engineer
(3,039 Views)
Thanks! I set the first option. I created only one layout and a script to load one TDMS per interaction, generate PDF for each one and then I merge the PDFs.
(3,027 Views)
